hard starting
hard starting
2007 EGC , pc3,k&n 6" air filter, rhinehart exhaust. after riding and getting up to normal temperature, starting is hard. motor turns over just seems like it is starving for fuel. when turning bike on the fuel pump whirs up like normal . battery tested out good . plugs good { gap and color }. after it sits for a bit it will start right up. ideas or thoughts appreciated. thx in advance
Still possible you have that pinhole leak if the high pressure hose was not routed differently than stock..........
It rubs against a brace in there.
With gas cap off.........
maybe about 1/4 tanks of fuel
listen(and even look) inside of tank while turning on ignition.......
Sound like it's spraying in there?
That's the leak that takes just enough pressure away so it won't start.
Then it will start out of the blue for no reason........finicky as hell!!!!
That's what my issue was at about 35k miles
manual says should change fuel filter every 25 miles.
