Twin Cam Motors Twin Cam 1998 thru 2017
2002 EFI Softail won't start
Old 09-18-2021 | 10:48 AM
Fuelishhabit@gmail.com's Avatar
1st Gear
Default 2002 EFI Softail won't start
Changed rocker cover gaskets and installed a new fuel pump/regulator/filter assembly. Bike ran before I did any of this. Won't start. Has 60PSI fuel pressure at the check valve outlet. Compression is 135 front and 130 rear,
Strong battery. Back fires out the exhaust and occasionally through the throttle body. Has spark at both cylinders. Changed Map sensor and crank position sensor. Same problem. Not showing any codes-just won't start.
Old 09-18-2021 | 01:31 PM
Max Headflow's Avatar
Max Headflow
Plug wires are swapped.
robb1178 (10-09-2022)
Old 09-18-2021 | 01:37 PM
1st Gear
That was it. We figured it out this morning. THANKS!!
benford46
06-16-2017 09:40 AM
amyjo30
03-13-2017 11:09 AM
Outamyleague
11-04-2015 12:57 PM
prospeed69
Exhaust System Topics
11-28-2012 10:13 PM
99 RK Classic
04-14-2007 11:57 PM
