Changed exhaust, but can't tune
Just worried it may cause damage if driven long-term.
Have a 103TC in a 2013 Fat Bob. All stock, including air cleaner.
Put on Vance Hines slip-ons but cannot tune ECU. (long story, but have FP3 with bluetooth issues)
Pipes look nice and I really don't want to take them back off.
Do you think its ok to leave them on and just ride it???
The following 2 users liked this post by Hecklerboy:
smitty901 (08-06-2021),
Uncle Larry (09-05-2021)
^^^^not true,
with slip ons and a high flow air cleaner, it needs to be tuned. throw the FP3 away as its worthless and either take it to a dyno shop and have it tuned, or get yourself a Powervision.
The TTS MasterTune and the PV are the best things out there, but real tuning takes time and experience, best to take it to a pro and then ride and have fun.
m
m
1 2 many (08-23-2021)
The following 2 users liked this post by Baird:
eighteight (08-09-2021),
While you can see the various opinions of individuals, the bottom line is your pipes can lean out the air/fuel mixture. Even the manufacturer’s instructions state it needs a tuner. If you cannot get the FF3 to work yourself, you need to find someone who can.
I doubt anyone who says run it as is will give you money to fix your motor if it gets hurt due to excessive heat.
Dave
Dave
98hotrodfatboy (08-21-2021)
I'm with Toe Cutter.
Here is a thread I started back in 2019, I think it will help you.
https://www.hdforums.com/forum/touri...tor-2-a-2.html
Ride safe!
Ride safe!
