Guys are these Battery and charging numbers okay?
It appears that the battery might be low but you really should check the voltage at 3000 rpm. If getting a maintainer, you are best off getting one that can do over an amp so that it can charge batteries beside maintain them. Tender make a 1 1/4 amp one. Noco makes a 5 amp one but you got to adapt to the tender plug.
I agree with Max; the battery may be tired; certainly worth a load test. Youj forgot one important test and that is the voltage drop on startup. Check the attached video for an informative walk through on motrocycle battery testing.
https://www.youtube.com/watch?v=-B8n9arZVyM
BTW in the video. the DMMs have a 1.5% difference in reading. I'd expect better.
BBTW, Thanks for the info on the other stuff.
Looks like your charging system is working. I’d just buy a new ( quality) battery and be done with it. Keep it on the ( hopefully smart charger) you bought when not ridden. IMO best solution. If bike has security, be sure you know procedure ( pull main fuse w/key on) before changing out battery.
Today was the first time I went to Wal-Mart for an oil change. Afterwards they gave me a “Battery Test Results” report saying “Battery fails to meet industry accepted standards and should be replaced” The results are:
Voltage: 12.79V
Measured: 402 CCA
Rated: 550 CCA
Temperature: 92 degrees F
I have no idea what these numbers mean. Do I need to replace it now, can I wait, and if I can wait, about how long?
Voltage: 12.79V
Measured: 402 CCA
Rated: 550 CCA
Voltage: 12.79V
Measured: 402 CCA
Rated: 550 CCA
Voltage: 12.79V
Measured: 402 CCA
Rated: 550 CCA
Voltage: 12.79V
Measured: 402 CCA
Rated: 550 CCA
Kodi nox
Voltage: 12.79V
Measured: 402 CCA
Rated: 550 CCA
Kodi nox
