Mileage for hydraulic cam chain tensioners
Hello All,
For those of you with TC engines (any displacement), that have converted to hydraulic cam chain tensioners or purchased a bike with stock hydraulic cam chain tensioners, how much mileage are you getting before having to change out the pads?
Thanks for the input!
After replacing the spring loaded tensioners twice, first at about 25000 miles and second at about 60000 I installed the screaming eagle tensioners with the new high volume oil pump. Last winter I removed the cam cover and peered inside with a dental mirror and flashlight and everything still looked good. This was just over 100,000 miles. I am running the stock cams and Mobile One V- twin oil
