Twin Cam Motors Twin Cam 1998 thru 2017
Transmission grinding noise
Old 06-29-2021, 07:13 PM
Seventy 7's Avatar
Seventy 7
Seventy 7 is offline
1st Gear
Default Transmission grinding noise
My bike's a 2002 Dyna Low Rider 88c.i. I searched everywhere and I can't see anyone else having this problem. All is good with the first gear, 4th and 5th, but when I shift in 2 gear I don't get the good solid clunk like it used to. I hear a lighter thin loose metallic sound, a lighter clunk and some grinding noise if I shift fast. There is no grinding if I let the rpms drop. I have this problem especially at high rpms. I hear a grinding sound in 3 gear as well but with a solid clunk and no metallic sound. The warmer the motor, the worst it gets. The grinding noise is the same as when you have the bike running on choke and you put it in first gear too slow. Can anyone help me with this?
Old 06-29-2021, 09:20 PM
TexasScooterTrash's Avatar
TexasScooterTrash
TexasScooterTrash is online now
Received 1,402 Likes on 859 Posts
Change yer trans fluid to Synthetic 75/140 gear oil and take it for a looooooog Road Test.
Old 06-30-2021, 03:01 AM
Seventy 7's Avatar
Seventy 7
1st Gear
Thanks but I'm not sure how that would help. It started doing that after a f****ed up a shift while racing someone. I downshifted hard and went a gear to low and dropped the clutch. Also I felt it going in wrong. I have a feeling I might have bent or broke something.
Old 06-30-2021, 06:35 AM
Weeboy1's Avatar
Weeboy1
Weeboy1 is offline
Valuable info that should have been included in post #1
Take it to a trusted Indy or at least seek their advice. It’s your your tranny! don’t let what maybe a small issue become a large expensive one.
Dick measuring contests sometimes come with consequences !
Btw welcome to the forum from Winnipeg Manitoba! (Presently visiting nearby in Ottawa)
Old 06-30-2021, 06:47 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 9,430 Likes on 5,023 Posts
Get out your service manual...
Remove the top cover and the clutch release cover (right side cover).
Remove the shift drum, slide out the shifter fork shaft, remove the shift forks and look them over carefully.
Seventy 7 (07-29-2021)
Old 06-30-2021, 07:23 AM
roussfam's Avatar
roussfam
roussfam is online now
Received 7,220 Likes on 3,753 Posts
Hey neighbor, Subscribed
Old 07-11-2021, 09:07 PM
jasle's Avatar
jasle
jasle is offline
I think you fugged the shift dogs. Going to need to split the tranny open. Otherwise you bent a shift fork.
Seventy 7 (07-11-2021)
Old 07-11-2021, 11:10 PM
Seventy 7's Avatar
Seventy 7
1st Gear
I will be trying that soon. Thank you
Old 07-11-2021, 11:13 PM
Seventy 7's Avatar
Seventy 7
1st Gear
I have a feeling that you are right. I will be going in there soon, waiting for a rainy weekend lol
Old 07-12-2021, 05:18 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
After a spot-on clutch adjustment to insure proper working order, and the problem still persists, pull the lid and take a look.
Scott
Quick Reply: Transmission grinding noise
