S&S CNC Ported heads on 88"TC
Hello,
I have been sitting on a pair of S&S CNC ported heads for over 10yrs as I was planning on doing a 95" build with 570 cams but never followed through.
I am now at the point that the cam tensioner shoes should be replaced and was thinking about upgrading to a 509 cam while it's opened up.
My question is will a stock bore 88" with 509 cams be ok with the CNC ported heads or will those heads on this mild setup be overkill?
I do have a big sucker air cleaner, wild pigs slip on mufflers and a Revolution Performance auto tuner on the bike now.
All I have to do with the tuner is mail it into Revolution Performance for them to download a base map with my combo and it auto adjusts from there. This tuner has been on my bike for over 10yrs and works well.
I understand the best route is gear drive or upgrade to the newer hydraulic cam tensioner setup but I'm on a very tight budget and have been told the aftermarket shoes hold up much better than the oem ones.
Thanks.
Thanks.
98hotrodfatboy (06-17-2021)
The bike is a roadking and I do like to get on it quite often but nothing crazy.
I'm sure something with good midrange will do it some good as I'm more highway riding than city/light to light.
I figure if I can at least use these heads with just a cam upgrade that would be great instead of them just sitting on the shelf.
I'll post chamber volume and valve sizes later on.
Thanks!
I measured them when I got them but since forgot. I will measure the combustion chambers when I get home later and report back.
The bike is a roadking and I do like to get on it quite often but nothing crazy. I'm sure something with good midrange will do it some good as I'm more highway riding than city/light to light. I figure if I can at least use these heads with just a cam upgrade that would be great instead of them just sitting on the shelf. I'll post chamber volume and valve sizes later on. Thanks!
tdd77 (06-16-2021)
If the chambers are +/-85cc, you are pretty locked in to the 509 cams. Even with a .030" head gasket CCP will be below 180psi and to really wake things up, you need more compression. More compression is available with domed pistons or decking the heads. I understand being on a tight budget but boring cylinders to build a 98" top end opens up cam selection and much more power. If that is out of the question, consider decking the heads about .035" to reduce chamber volume to 80cc. The compression increase will wake things up nicely.
Correct me if I'm wrong with any of this.
The heads have springs that can handle .575 lift.
I used a little measuring cup that measures in milliliters with some motor oil and filled the chamber and intake runner.
looks like combustion chamber is 80cc.
Intake valve 1.90"
Exhaust valve 1.60
Intake runner 90cc
Maybe I should just check the tensioner shoes and if they're good run it through the summer/fall and squirrel away some cash till winter to do a big bore in the winter.
Originally Posted by tdd77
Ok so I attached a bunch of pictures to make it easier for anyone that might not quite understand. Correct me if I'm wrong with any of this.
Intake valve 1.90"
Exhaust valve 1.60
Intake runner 90cc
Intake valve 1.90"
Exhaust valve 1.60
Intake runner 90cc
blksoftail
Exhaust System Topics
07-15-2011 11:30 AM
