Twin Cam Motors Twin Cam 1998 thru 2017
Andrew 26g Cam shaft suprise
Old 07-01-2021, 08:40 PM
jasle's Avatar
jasle
jasle is offline
Originally Posted by djl
I have never used the Jim's tool; always just pressed directly on the nose of the cam. If the key is firmly seated in the slot in the nose of the cam and aligned with the gear slot and the gear tapped on to get the process started, the gear should press on without issue, particularly if the cam was "frozen" and the gear heated. In your pictures, it doesn't look to me like the woodruff key is firmly seated in the cam slot.
I agree if you freeze the cam and warm the gear. (I use heat gun) you can generally slide the gear on without a press. Mild use of arbor press but not really..
Smiley13
EVO
06-13-2021 07:44 AM
Smiley13
06-13-2021 07:25 AM
Keener
Exhaust System Topics
12-26-2008 10:33 PM
Road King Kid
21
01-20-2008 07:47 PM
Taterdog
11-27-2007 07:10 PM
Quick Reply: Andrew 26g Cam shaft suprise
