Motor stopped, sudden oil leak.
#41
Received 4,412 Likes
#42
#43
Harley1004 (06-26-2021)
#44
#45
#46
#47
#48
If the rod bearing went, the motor should have knocked. It didn't. If that were the case the rear rod nub would have been up against the back side of the front rod. The nub is in front. Look at the picture of the crank in the cases (down is forward). If the bearing stuck, the remaining part of the rear rod would have jammed up against the front. Instead, the rear rod remains are in front of the rear rod. This means it was moving and as knocked holes in the case, it rotated backwards.
#49
#50
