primary noise same deluxe more problems...
#41
TSB was clamp-load only. It did not address nut bottoming out. You would have to use a beam style torque wrench. Torque and turn is just way more accurate than a torque spec.
We had so many loose comp nuts in 03-05 I used to just tell everyone i knew who had or bought one to open it up and check for loose.
#42
Item 12 here: Get one and put it under the nut. Min .030. I think a .060 would probably do it for sure. Been forever since I had mine apart and measured all the stackups. Maybe Max Headflow has an opinion - he might have a safe spec in his head.
https://partsfinder.onlinemicrofiche...ND%20SPROCKETS
#43
You need to realize that you’re going to need to check the alignment of your primary chain and that is going to dictate what spacer you’re going to buy for underneath the sprocket. If you’re not going to cut or grind down the nut you’re also going to buy a .060” or .090” spacer for under the nut. So you’re going to have to do some measurements and we really can’t just assume which size to order. If that bag of them you asked about in a previous post is a bag of assorted sprocket shaft washers that may be your easiest solution.
The reason cutting the nut down is better is that it creates one less joint that must retain clamp-load.
#44
if I'm reading things right 0.02 is listed as the factory default size with the others being listed as "as needed" with the small price tag I'd gladly buy a couple of each that I could find locally. if I can't find them locally tomorrow I'm probably going to end up placing another order online for an assortment of sizes and paying for the fastest shipping I can get. I don't like throwing money away but time is very valuable to me especially riding time lol. I'd rather spend another $50 to finish the job on my next day off than waste that day off and have to wait for another to save a few dollars. time is the only reason I'm even still messing with it. couldn't get it into the Indy for over a month when my problems started. I'm still 2 weeks out from that appointment
#45
the ones I previously ordered are a 5pk of 0.032 I was told the exact thickness of the shim wasn't very important since it was just to keep the nut from bottoming out and that anything between 0.02 and 0.09 would be fine for that. and yes there is a lot I need to realize, I don't hide the fact that this is all new to me. I have zero experience inside an HD motor and am relying on the manual, youtube, and you gentleman here on the forums to learn. you were the first to catch the fact that the pieces I found might have been the spacer from behind the sprocket. I think the rest of us assumed what I found was from a shim behind the nut. since I wasn't aware I was missing another piece in the stack the thought that I would need to mess with measuring alignment never crossed my mind. my line of thought was replace Parts in order they came off and either shim or cut nut then check chain tension and close it up. if your right you probably just really saved my ***. I won't know if I'm missing a spacer or not till I get home tomorrow and look.
#46
Was not a knock or being sarcastic. Was trying to have you take a moment and understand that there is some measuring and working through it. Everyone is trying to give you the best advice to help you through it. For the original spacer to be broken, it must also be very worn, but you know that any spacer you order will be as thick (realistically thicker) than it.
#47
Surprise surprise the mystery pieces I found were the spacer from behind the sprocket against the face of the rotor. I am surprised with the thickness measurement which averages 0.061 . That seems awful thick considering I have no idea how much of it wore away before it got to this point. So unless I can stack two of the 0.032 shim's I have on the way for a total of 0.064 and be extremely lucky it seems I'm going to be ordering parts again. I'll have to dig into the manual and see if it explains how I'm supposed to measure for the alignment I didn't find much on Google
edit yes manual describes how to measure but I'm having trouble visualizing it. I'll have to try it after getting some sleep. The part numbers in the manual for the spacers jump from 0.060 straight to 0.090 then 0.120.
#48
TSB was clamp-load only. It did not address nut bottoming out. You would have to use a beam style torque wrench. Torque and turn is just way more accurate than a torque spec. We had so many loose comp nuts in 03-05 I used to just tell everyone i knew who had or bought one to open it up and check for loose.
I am thinking the OP might get lucky. With the shim being between the nut and the rotor, we must assume someone has been in the primary to address a loose comp nut and the sprocket may be aligned. Of course the OP should check but it the sprocket is aligned, a .090" cut on the nut and new rotor could be all he OP needs to get back on the road.
#49
Understood; just making the point that the nut bottoming out has to be addressed regardless of what torque procedure is used. Sill curious what torque load is at 75ft.lb. plus 40*.
#50
another thing I'm having trouble wrapping my head around is which parts are going to change the measurement of the shim needed for alignment? I would think the new rotor would definitely change the measurement but would a new nut or cutting the nut? I'm thinking not but I could be wrong. While searching for these parts I also came across a 24 tooth sprocket but I have thought about switching to later but I'm guessing that would require me to re-measure and switch Sims again.
