Cam Chest Questions
The following 2 users liked this post by rol427:
brownie4412 (05-12-2021),
eighteight (05-11-2021)
correct.. therefore taking less heat out of the engine..
The following 2 users liked this post by djl:
98hotrodfatboy (05-11-2021),
Cheers!
That's possible. Hmmmm...... maybe I should go do a few dyno pulls. If I was sumping before the new plate/pump and made 131/135 , I wonder how much was potentially lost? Power loss is a symptom of sumping no?
Very interesting.
Very interesting.
If a bike was just sitting and idling yes a higher flow oil system would in all likelihood result in that bike getting hotter faster.
The same principle applies to air. Does your bike run hotter in town at 25mph or on the interstate at 80mph? Why does the tuner point a big *** fan at your bike when it's on the dyno instead of just cracking a window? More flow, more heat moved.
Clammy (05-12-2021)
Monitoring the engine temp on the street and doing a dyno pull are 2 separate things. My FXR put out 144/146 on the dyno I used but run it at 75 with ambient temps above 90F and it would sump until I replaced the Fueling Race pump with a SnS 3 rotor. Could feel it sumping on the street but not on the dyno.
Can I jump here and ask...Is it possible to test an oil pump to see if it is working properly, after the engine has been torn down? I ask this because my mechanic told I would need a new oil pump, but he had already tore apart the engine. How could he tell if he did not have the bike running and he was working on the top end?
