Recommended tuner for S&S 509 cams ?
I'm looking to throw a set of S&S 509 cams in my 05 ultra classic (fuel injected).
So far the bike only has a set of American custom Bomber slip ons, stock everything else.
I'm thinking of also doing an S&S teardrop intake at the same time I do the cams.
What would be the best most price efficient tuner for this setup, and would work well with a future dyno tune?
Fuelpak3? Power commander v? Power vision?
Thanks for any input!
Powervision or TTS Mastertune. My vote goes to the TTS Mastertune as designed by the same person that was instrumental in the development of Harley's Delphi ECM and is designed specifically for Harleys.
Best tuner...TTS Mastertune
User Friendly interface...PV
Power Vision from fuel moto. The tune and support they give you is excellent and the price is the best. I had some major mods and the tune they gave me out of the gate was pretty good. WAY better than the dynojet one. I sent in a few requests based on rideability to modify the tune and now it's pretty near perfect. Don't think I'm going to bother with a dyno tune either. Definitely the way to go.
The following 2 users liked this post by Mark Pisani:
98hotrodfatboy (04-30-2021),
blackgt85 (05-02-2021)
I am using PV with the Auto tune kit. I also used V&H dresser Dual's for the 02 bungs. Expensive upgrade, but the AT really dialed in the base tune from Fuel Moto. Running Andrews 21's, SE air cleaner kit and Crusher Mellow muffs. I have tweaked the tune several times, the most recent was after an injector swap, my 06 had the old style 8 degree injectors. It has payed for itself vs several dyno tunes I would have had to do
05's do not have 02 bungs so you would be stuck with old style FP and the canned maps do not play well with cams.......ask me how I know
Powervision either from a local tuner that sells customer licenses which means the customer doesn't have to purchase the system or as others have said from Fuel Moto with a base map. Adding 'O2 bungs is not a problem; added them to the Bassani Prostreets on my '05 FXSTD. JMHO but finding a local tuner that tunes with the Powervision via the license program and can add the O2 bungs would be the route I would choose.
Iron lHorse
Exhaust System Topics
16
10-26-2013 12:04 AM
