INstalling Hybrid Cam Plate on 03 RKC
I currently have 93,764 on the clock, and have been having some sumping problems at high rpms. I was near the back on our last club ride, and the poor **** behind me got some oil spray when we were pushing 85-90mph. I resigned myself that it was time to get back in to the cam chest and check the oil pump and such out. I was last in there May 2019 with 78,998 miles (14,766 miles ago). I replaced the tensioner pads then with some cyco shoes, and put a new chain guide on. Everything else looked good.
I decided to just go ahead and order the hybrid camp plate with the new oil pump. It certainly wouldn't hurt, and the new oil pump may just solve the high rpm sumping issues. A couple of tensioner shoe changes ago, I measured the crank runout, and it is just on the cusp of too much for gear drive cams.
Well, this time it is kind of s**t show. The outside tensioner is gone. Like GONE. The chain guide is broken and chewed up. This is only after just over 14.5k miles.
**Please look at the camshafts in the last picture for this post. Give me your opinion, good or bad. I'm thinking bad.**
A bunch of chewed up s**t stuffed into the pressure relief tube.
Various chewed up and broken pieces I pulled out.
The inside tensioner pad after 14.5k miles.
This is what I would like folks to weigh in on. The surface on the rear camshaft is pretty rough. I honestly don't remember what it looked like the last time I changed the tensioner pads and had this out of the cam chest. I'm pretty damn sure it didn't look like this though, or I would have noticed. I'm thinking it's time for new cams.
The following 2 users liked this post by Weeboy1:
crazytown (03-26-2021),
slippin_jimmy (04-13-2021)
Also, not sure the motor was sumping. At near 94K miles ring seal is probably lacking and the unfortunate soul that got sprayed was most likely catching high rpm blow by.
crazytown (03-27-2021)
The cycos still use the stock arm and spring, If riveted incorrectly or done more then once, the arm may have failed and everything got chewed up in the process. As far as sumping goes. look at the oil pickup. It's plugged with crap. As DLJ says you'll want to replace the inner cam bearings. You'll also want to remove and clean the oil pan.
I ordered new cams; S&S 509c. I think I will just replace both inner bearings while I'm in there. Why not?
10-4 on all that. For what it's worth, the 'cyco' pads were ordered from http://twincamtensioner.com/, which as far as I know is a legitimate source. I'm certainly not going to discount user installation error on my part. It wouldn't be the first time for sure. I ordered new cams; S&S 509c. I think I will just replace both inner bearings while I'm in there. Why not?
