Cam recommended for 97”
If you want help from this forum, you need to provide more details about the build plan.
samsquanch (04-18-2021)
You need to do more homework. Those are two very different cams; the 551 intake closes at 19* and the Rocket 554 closes intake closes at 38*. You need to better understand cam profiles, compression and matching components to produce the desired results. Stock '04 valve springs will not accommodate lifts greater the .500".
98hotrodfatboy (03-24-2021)
So valve lift won't be a problem but as I said in my previous, the two cams referenced in your previous post are very different profiles and you need to figure out which profile will provide the results you are looking for, i.e., which best matched riding style.
