Planning Andrews cam upgrade, other things worth doing while inside?
Have you adjusted the A/F idle screw? How many turns out? This needs to be done to test the pilot jet. Not suggesting that this is causing the stutter but an important step and IMHO, the first step in tuning a CV carb.
Have you checked the float level? It may need adjusting.
Do you have the cables so you can upload/download the ignition map from the DTT? If not, suggest that you get them although I don't think timing is the issue with high rpm stutter but looking at the ignition map and being able to manually make adjustments is a benefit. While timing is important for obvious reasons, don't expect timing to make a big difference in performance. Some adjust the ignition curve by starting at 2 on the initial and advancing a click until they get a ping and back off a click, then do the same with advance slope.
I ran a CV44 on my all bore 107 which I ran pretty hard, always 75-80mph wherever I could. Mileage wasn't great but averaged between 36-38mpg depending on the terrain and wind; your mileage should be at least that and I would expect a bit better, so you have some work to do.
I sold that bike last year along with the DTT software/hardware but I do have some ignition files on my computer that I can send but you will need the program to open the files and/or download them to your DTT. PM me if interested.
I did check the level a while back. It wouldn't hurt for me to check it again. I do know that when I have had the fuel line removed, and I would take the bowl off to change the jet, the bowl is about 1/8-1/4" from full, with fuel.
Thanks for the help, as you said, I've got some work to do! (I'll PM ya for that ignition file if you still have it. Thanks)
Carl '69 (08-19-2021)
The reason I asked. Hard to tell without listening to the motor while adjusting. I would keep turning out while listening before making the call on the slow jet. I like 2-2.5 as well.
So I took a look at my plugs. These were put in just after the cam change, oil change, start of the season. I've never had them look like this after an entire season or 2. It may be from when I had the 195/48 combo and it was running rich(??)
I also had oil really breathing out today again. It has a light spray on the hard bag and tour pack. First of all, I need to see if I screwed something up with the oil pump reinstallation (I followed the tightening of the bolts, after pump was put in, then the cam plate). I did not have this much excess before the cam change. I had a little, but the drilling out the top drain holes in the rocker box fixed it. (I still plan on getting the catch can kit, but still not sure it should be doing it this much)
Also, since the K&N filter is getting oil-soaked, that's probably choking off the air.
Left plug is front, right is rear
When was the last time you checked compression and leak down? Front plug is reading rich and, if wet, oil is getting into the cylinder. I could live with the rear, Having said that, to accurately read plugs, plug cuts should be taken with new plugs at different throttle positions to check AFR at that throttle position.
Also, it looks like I've got a lot more homework to do with this troubleshooting. Trying to absorb all I can from other forum posts and resources. I appreciate all the replies!
