Twin Cam Motors Twin Cam 1998 thru 2017
S&S583 vs S&SMR103?
Old 05-07-2021, 02:00 PM
60Gunner's Avatar
60Gunner
60Gunner is offline
Received 1,212 Likes on 904 Posts
Well, like ya said, you like to engineer the combinations. But what happens when someone wants or is running something outside your norm? Different exhaust requires a different tune. Often way different. Especially timing.
There are builders here, not saying you're one of them, that are responsible for people.here believing that they need a 2in1 exhaust to make any kind of decent power. Why? Probably cuz is all they know how to tune because it's one of the biggest lines of pure bs here. I know full well what my exhaust is capable of.
I have no faith in builders/tuners in general here because of widespread misconceptions like this that started with them. I'd have to have a screw loose to let one of them tune my bike or even worse, do my head work.
Another thing is cams and compression ratios. Can't run those cams without a compression bump. I can't count the number of times I hear that about anything but torque cams. Including the 570s I'm running in my 103. Nevermind my CC was 190psi with them in a bone stock 103. 200psi now with just a .030 head gasket. Much more compression and it would be ping city.
I cringe when I hear people like the OP here putting cams like the 583s in bikes like his. Where do they get this from?
You're from the racing world? Then you know full well in that world, hp wins races yet the general consensus is just the opposite. And gearing is huge yet not one builder here that I know of anyway advocates or ever recommends it for people whose riding style would sure benefit from it. In a big way. It can be a huge bump in power to the rear wheel in bikes whose gearing leaves a lot to be desired for many of us.
Granted not everyone rides the same and we're mostly dealing with street bikes, not race bikes, but it takes a good balance or low end torque and hp to make a good street bike.
This isn't directed at you, Scott. Just what I see going on here in general and why there's such a distrust among some of us when it comes to things like dyno numbers.
More often than not, those peak numbers really don't mean jack anyway. It's not what makes a build. But we're all guilty of putting way too much stock in that piece of paper at one time or another.
Old 05-07-2021, 03:40 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 5,466 Likes on 3,643 Posts
So if you were Building a hot rod you wouldn't want this
with an RB Racing 2-1????
By the way I loved this build Because how that two in one pipe allows the torque to come on SO massively.... But still carry out.......
Old 05-07-2021, 04:21 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 6,016 Likes on 4,064 Posts
Only 65 fp at 2700 RPM? pretty sad. I'd change the pipe.
Old 05-07-2021, 07:39 PM
98hotrodfatboy
Max.... It's only an 80"Evo...
Old 05-07-2021, 07:52 PM
Max Headflow
I know.. Still not too hot on the pipe. Tried one a 95 ci TC and didn't like it..
Old 05-07-2021, 10:16 PM
98hotrodfatboy
it sounded great though...
rons73
Engine Mechanical Topics
10-15-2020 06:08 PM
artkrhymes
02-05-2015 01:04 AM
shootist
06-03-2013 06:35 PM
EasyriderFI
Exhaust System Topics
02-01-2010 06:03 AM
timberwolfz28
08-10-2008 11:27 PM
Quick Reply: S&S583 vs S&SMR103?
