Twin Cam Motors Twin Cam 1998 thru 2017
Question about 96" to 103" BB upgrade?
Old 03-16-2021, 02:36 PM
djl's Avatar
djl
djl is online now
Received 2,227 Likes on 1,611 Posts
AT 10:1 static with a good 2:1 exhaust I am guessing TQ should start ramping up around 2600rpms but having never run that cam, it's an educated guess. Whenever comparing notes or dyno sheets it is important to know the compression for an accurate comparison. The 585 at 9:1 won't act the same as it will at 10:1; for that matter, that can be said for any cam. There are members here running that cam; maybe they will chime in with some ground truth. Probably a dyno sheet or two in the Dyno Room as well.
Old 03-17-2021, 08:15 PM
Adam76's Avatar
Adam76
Adam76 is offline
Originally Posted by djl
At 10:1 the 255 won't be a good fit. Maybe the S&S585.
Andrews 48H might be a good fit at 10-1 ?
Old 03-17-2021, 08:18 PM
Adam76's Avatar
Adam76
Adam76 is offline
I'm looking at helping a friend to do a 96 - 103 big bore and I'm thinking of using the Andrews 54H set at around 10.2 - 10.5 compression, depending ones this cam likes the best. 10.5 puts the motor at 200ccp.
Old 03-20-2021, 02:47 PM
djl's Avatar
djl
djl is online now
JMHO but I am thinking the 57 would be a better choice; same profile as the very popular 37 but with more lift.
Old 03-23-2021, 12:43 PM
Chrriss69's Avatar
Chrriss69
Chrriss69 is offline
Default Fueling cams
Hey guys...
im doing the same kinda build. The guy I got the bike from had the BB already done. He had the CNC ported heads SE pistons and SE 259 E cams, stock cam plate and pump. I had issues and had to hear her down.
I now have Wiseco domed pistons, oversized rings, went .010 over. HP+ Fueling cam chest with the 574 cams. Found the crank was bad and just ordered a Darkhorse Man o War crank and gunna run lefty bearings on both sides.
Oh, 96-103 BB, 10.5-1 compression
Any feedback as this is my first build?
Old 03-23-2021, 02:14 PM
Chrriss69's Avatar
Chrriss69
Default Fng
So.... is what I did considered a ripoff of home boys thread? If so I apologize, I’m new to the forum thing...
Old 03-23-2021, 02:15 PM
djl's Avatar
djl
djl is online now
What's the piston dome CC? Are the heads HD heads or CNC ported by someone else? Chamber volume? There are some who will tell you that you should have the Timken conversion done in lieu of the Lefty bearings, which, of course is good advice. However, I used two lefty bearings in my last 98" build (115/115)and, so far, no issues.
Old 03-23-2021, 02:22 PM
jordan1200's Avatar
jordan1200
jordan1200 is offline
No worries, we are all here to help one another
Old 03-23-2021, 02:30 PM
Chrriss69's Avatar
Chrriss69
Hey djl!
I do know the heads are the SE ported, not sure of the technical questions. This is my first full build so I’m kinda flyin by the seat of my pants. Have been doing a lot of research and think this might make a good combo. I was just lookin fer some lower range HP/TQ, hope I’ll get what I’m lookin fer! I think fer the dollars the two lefty bearings will handle what I’ll end up with just fine🤷🏼‍♂️
Old 03-23-2021, 02:31 PM
Chrriss69's Avatar
Chrriss69
Thank you Jorden, I’ll get the hang of it!
Quick Reply: Question about 96" to 103" BB upgrade?
