Which Ignition set up for a 2002 carbed fatboy? Doing cams and 97" kit
Thanks Scott, I assume you meant "very tuner friendly" 😉 and was referring to the DDT.
I have to replace my coil anyway, do you suggest a stock oem coil? Or something aftermarket to go with the DTT ignition?
thanks
thanks
The stock coil on these bikes puts out way more than enough. I run stock on a 11.3 to 1 116 ci Dyna and a 11.0 to 1 131 ci FXR. Tried the DTT high output coil on a FXR and as far as I can tell, it made no difference. When HD went to the twincams, they used and coil with a 1/2 ohm primary. Stock coils are driven pretty hard, mainly because they bike from the factory are run lean and it's harder to light the mixture. Most of the performance guys use stock coils.
I am picking up a replacement coil and keeping my 19 yr old stock coil as a back up...
For a replacement coil to go with my 95" build and DTT ignition - do I get the stock 0.5 Ohm genuine Harley oem coil? Or do I get a single fire 0.5 replacement coil from J&P cycles or do I get the 3 Ohm twin power coil?
Just not sure which works best with the DTT set up and the mods and I'm assuming I'm going to be using the single fire mode? So do I need a single fire coil? Confused.
Thanks for any advice
Thanks Max,
Don't buy a 3 ohm coil. It's for EVOs.
All twin-cam coils are single fire.
You should be able to get any 0.5 ohm coil for a carbed twincam that fits your bike. The only experience I have is with the stock HD and DTT coils. The only reason why I tried the DTT coil was that my suspected electrical problem turned out to be carburetor.
You're a legend. 😁
