Cam Chain Tensioners????
Ive got an 03' FXSTFI ,picked it up about 4 moths ago but hadn't ridden much at first.
changed bars, controls, cables etc.
24,000 miles, runs excellent & sounds excellent.
no knocks, vibrations, noises etc.
changed all 3 fluids about 85 miles ago, Oil was dirty but no metal Whatsoever. The magnet on the plug was clean.
This is my 1st twin Cam, All I keep hearing, is how the cam chain Tesioners will break up, & destroy my engine if i dont change them??
Can someone give me some insight on this please.
I have no problem pulling it apart & changing things is it something i definitely need to do sooner before later..
i do all my own work but i havnt done alot of engine work.
How complicated is it & whats my best option?
hydraulic, gear driven, just different tensioners or should i do nothing???
knowledgeable comments appreciated!🍻
You won't know what shape the tensioner system is in unless you inspect it.
After researching the same issue for my 2001, I just went ahead and installed the HD hydraulic cam chain tensioner kit. The original tensioner was ok, but the spring loaded setup is not as reliable as the hydraulic.
Kit costs about 500 bucks. The time in between recommended inspections is much better with hydraulic and you won't have to worry about the original system breaking.
IronAss (08-31-2020)
The early twin Cams 1999-2006 had some issues.
1. Spring loaded cam tensionars can and will break apart. If this happens it can ruin the engine. Most people convert them to the screaming eagle cam plate . There are a few ways you can go at this issue
2. Inner cam bearings. Most people upgrade these when they take care of the first issue
Harley1004 (09-24-2020)
As has been said, several ways to address the issue and the all vary in price, so how the OP chooses to address the issue may depend on funds available. What I read is the OP has a stock bike, maybe Stage I the is in good condition and running well with no mention of performance upgrades planned for the immediate future. 24K miles is the point where many have experienced tensioner failure. The tensioners on my '02 FLHT were gone at 25K miles and at 12K miles on my '05 FXSTD. The most cost effective way to address the tensioner issue would be to replace the OEM tensioners with a set of CYCO tensioners which requires removing the cams from the cam plate which requires replacing the outer cam bearings. As has been suggested, the inner cam bearing should be replaced wtih a set Koyo/Torrington B-148s. Pay attention to the direction of the chain rotation so it can be replaced the way it cam off. At 24K miles, I would replace the lifters as well with an aftermarket lifter. Of course, the oil pump, scavenge port and cam plate o-rings should be replaced as well.
Time consuming job but not mechanically challenging. A bearing puller/install tool will be required for the inner cam bearings will be required as well as the pressing in/out of inner cam bearngs and cams. There are work arounds for those operations. If the OP doesn't have the service manual that is the first thing he should purchase.
If you don't already have one, get a factory service manual. Very helpful!
The cam chain tensioners on the early twin cams is a plastic shoe that has a spring pressing it into the cam chain to make tension. The service life I've always heard for these was 20k. If you're not planning to do anything high performance then just pull the cam cover off and inspect and replace as needed with OEM parts and youl'' be okay. If performance is in your future then get a hydraulic tensioner upgrade or gear drive cams.
Thantos (03-06-2021)
The cam chain tensioners are a plastic shoe that rides on the cam chain to keep it tight. Eventually the plastic shoe wears out or breaks and there’s your problems. I’ve always heard that you should check or change them every 20k miles.
as far as solutions here’s your options. 1. Check them and replace as needed. 2. Do an upgrade to hydraulic tensioners with a new cam plate and so on. 3 upgrade to gear drive cams, this is the most expensive and most difficult but would also be the most durable.
if it was me, I would just check and replace as needed unless you’re interested in performance. If that’s the case then I’d be getting performance cams and upgrading everything at once probably going with the hydraulic cam tensioner option and then getting performance chain drive cams.
my guess is that there’s probably a how to video of all this on the interwebs somewhere already
There are basically 4 options for you to consider:
1. Gear cam upgrade (expensive)
2. Hydraulic tensioner upgrade (expensive)
3. Tensioner shoe upgrade to the CYCO shoes (relatively cheap)
4. Do nothing (not a good option IMO)
I did option 3. While I was in there, I changed the inner cam bearings and upgrade to the Andrews TW21 cams. Not hard to do if you have a factory service manual and the right tools.
s-glide76 (09-22-2020)
