Twin Cam Motors Twin Cam 1998 thru 2017
SE585 Cam experience
Old 07-24-2020, 05:19 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
How'd this turn out?
Noise still there?
We load the lifter to .140".
Even cams with lifts north of .650" run quietly.
Scott
Old 07-24-2020, 06:16 PM
Mattbastard's Avatar
Mattbastard
Mattbastard is offline
Received 1,415 Likes on 866 Posts
Originally Posted by djl
Still betting the test procedure was not correct.
Yea, like not going WFO on the throttle before cranking the engine over.
Speaking of that, every since I blew up a gauge I crank the engine over a couple times first with the throttle open and the spark plug out, THEN I install the gauge. When I blew the gauge it was because the accelerator pump jacked some fuel into the intake and the hot engine auto-ignited that mixture on the first crank.
Old 07-24-2020, 06:22 PM
Stoney Lawson's Avatar
Stoney Lawson
Stoney Lawson is offline
I meant to reply. I did do the test wrong.
i left the compression releases connected
Ended up being
front 182
rear 180
Mattbastard (07-24-2020)
Old 07-24-2020, 07:19 PM
Stoney Lawson
The cold start tick I heard was an exhaust leak from the crossover pipe.
Dealer is saying the bike Is okay and won't tear it down until there's an issue that my warranty can actually address.
Old 06-25-2021, 07:28 PM
Ajabel24's Avatar
Ajabel24
Ajabel24 is offline
6th Gear
Default Same lifter noise
Came across this and sounds awfully familiar. Did fixing the exhaust leak fix the noise? I changed lifters on mine three times. Starts off quiet and after 200 miles the noise comes back. Cams have been removed and reinstalled twice, rocket lockers and still nothing. Mine sounds worse around 3000-3500+ rpm. Don’t mean to steal the thread but I’m about to go back to stock. Currently running the se 585 with s&s lifters with the se race double springs and perfect fit push rods
Old 06-25-2021, 07:46 PM
djl's Avatar
djl
djl is online now
Received 2,227 Likes on 1,611 Posts
Those heavy springs could be the culprit; they can slam the valve back into the seat. OEM beehives would probably solve the problem.
Old 06-25-2021, 08:18 PM
Ajabel24's Avatar
Ajabel24
Ajabel24 is offline
6th Gear
even with 585 cams?? I see the behive springs from SE that are for up to .590 lift but the double springs is what they sold me. I agree they are too heavy for my application. I would happily put sticks back on but what’s the max lift for the stock springs?
Old 06-25-2021, 08:24 PM
60Gunner's Avatar
60Gunner
60Gunner is offline
Received 1,212 Likes on 904 Posts
585s are about max but there's plenty of the 585s running with the stock behives.
Ajabel24 (06-25-2021)
Old 06-25-2021, 08:32 PM
Ajabel24's Avatar
Ajabel24
Ajabel24 is offline
6th Gear
think so? I don’t want to float the valves. I guess I could through them in and if that doesn’t work, just put stock back in
Old 06-26-2021, 04:26 PM
djl's Avatar
djl
djl is online now
I have run .600" lift cams on OEM springs and rockers in my '02FLHT (110HP/124TQ) with no issues and never babied that bike. Loved showing tail lights to the 114" M8s. I ran .590" lift cams in that same bike without trimming the main boss bearing and the bottom of the lifter block castings; clearance was .030". However, when I replace those cams with the .600" lift cams, I did need to clear both areas; not an issue with the later models.
slippin_jimmy (06-29-2021)
Treynolds03
Milwaukee Eight (M8)
21
01-23-2022 10:59 AM
johnwesley
Engine Mechanical Topics
02-11-2018 12:30 AM
94 ultra
2014-2023 Touring Models
10-23-2016 08:44 PM
blair
02-24-2015 12:42 PM
busterman2
EVO
11-26-2012 09:59 AM
Quick Reply: SE585 Cam experience
