Twin Cam Motors Twin Cam 1998 thru 2017
SE585 Cam experience
Old 06-23-2020, 12:40 PM
slippin_jimmy's Avatar
slippin_jimmy
slippin_jimmy is offline
Originally Posted by Stoney Lawson
Does anyone have any experience with this cam?
I have it in my 14 ULTRALTD and it's extremely noisy as far as valve train goes, I know I have .030 pushrods and stock lifters.
Just wondering as it says it's supposed to quiet down valvetrain lol
Are they gear drive cams? Those will be noisier but no chain and tensioner to worry about.
Old 06-23-2020, 12:49 PM
Stoney Lawson's Avatar
Stoney Lawson
Stoney Lawson is offline
Originally Posted by 60Gunner
Damn. Just listened to your video. That's pretty bad. You say it's a cold start issue and goes away as it warms up?
precisely, no one has any idea what it is
Old 06-23-2020, 01:34 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is online now
Received 30,894 Likes on 11,610 Posts
If it’s there when the motor is cold, and If it goes away after a bit of time, doesn’t that mean it’s a lifter not coming up? I had a similar, but louder noise on my M8, it was there when started cold, and went away after about 20 seconds. Replaced the lifters with S&S lifters when I did the torque cam...no more noise like that.
Old 06-23-2020, 01:35 PM
Stoney Lawson
I replaced the lifters with meling lifter and same issue, i'll grab the S&S lifters and try again, i think it may have to do with the pushrods as well, maybe one is bent
Old 06-25-2020, 01:53 PM
Stoney Lawson
An update:
cold started it today, and can hear the ticking through the left exhuast pipe, can only assume at this point that it's the exhaust valve either burned or stuck on cold start
Old 06-25-2020, 02:08 PM
Stoney Lawson
Just did compression test
front 120psi hot
rear 95psi hot
Old 07-11-2020, 06:12 AM
Tail Rid'r's Avatar
Tail Rid'r
Tail Rid'r is offline
How have you made out with your issue?
Old 07-11-2020, 10:10 AM
djl's Avatar
djl
djl is online now
Received 2,227 Likes on 1,611 Posts
front 120psi hot
rear 95psi hot
Test was not done right; I would expect to see 180-185. Even so, the difference between front and rear is troublesome.
Hillsidecycle.com (07-12-2020)
Old 07-11-2020, 11:41 AM
60Gunner's Avatar
60Gunner
60Gunner is offline
Received 1,212 Likes on 904 Posts
It's the gauge he's using. Bet it doesn't have a shrader valve in the end of the fitting that goes in the head. The junk you buy at harbor freight, several of them actually, are like that. One is a Pittsburgh. Use to have one. There's reviews and videos all over about them. They add significantly to the volume you're testing. They're fine for telling if one cylinder is worse but junk if you want to know your actual compression. There is a methematical correction but don't ask me what it is. You have to know the volume of the hose is you're adding to the combustion chamber volume.
I made a leakdown tester out of mine with a few spare parts and bought a decent Actron compression tester. Read 65psi more on my Sporty.
Old 07-12-2020, 01:44 PM
djl's Avatar
djl
djl is online now
Still betting the test procedure was not correct.
Quick Reply: SE585 Cam experience
