Twin Peaks 10" Apes
One heads up...even if the TBW is long enough, many times they get damaged when being removed from the stock bars. Most dealers have a blanket policy of just replacing the TBW unit whenever changing bars, even if it's the same length.
Most shops will not even order wires/lines until the new bars are on so they can measure everything from there.
When putting taller bars on my bikes I have had good luck using a string to measure existing length and then mocking up the new bars and using string to see what is long enough and what needs to be longer.
On my 14 TG I went 9" taller than stock and had to extend all wires and get new clutch and brake lines.
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
OR
steelerdude1
2014-2023 Touring Models
11-11-2015 06:37 PM
