lift kit advice please
hi im getting a new triglide and i will have the dealer put a lift kit on it for me, my question is are all the lift kits basically the same ? i read a thread today that someone lloved the comfort ride kit they put on and the dealer had a diffrent brand do they all perform the same or is one better than another as far as ride quality goes ?? thanks
If you are a very aggressive rider the standard lift is recommended for the extra support. Less aggressive, then the comfort lift might be in order.
All the lifts give the same distance of lift to the rear of the trike. Also a must for the exhaust clearance. When you put the lift on you can also lower the shock air pressure & this helps with the ride also.
Hope this helps ya.
Welcome to the forum !
Rise Safe
The three kits used here by most on this forum are all quality kits. Two kits are the same, in they do the same thing. The comfort kit changes the leverage of the arm to the shock. This is done to give a softer ride.
Hope this helps ya.
Rise Safe
Hope this helps ya.
Rise Safe
My advice is get one! (I have the comfort lift from DK products)
Received 4,230 Likes
Here is a link to the Standard Lift and the Comfort Lift. I personally use the Comfort Lift.
http://www.dkcustomproducts.com/Tri-...t-Kits_c56.htm
If you would like us to work with your dealer, or let you know of a dealer in your area, just contact us at the email or number below.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
Hope this helps ya.
Rise Safe
Hope this helps ya.
Rise Safe
M3, I wasn't sure anybody else running standard lifts was curious enough to try the comfort lift. I see you and I have gotten the same results too. Coin toss works pretty good
I do experiment from time to time, heck I've had 3 different sets of clutch plates in my 06 Ultra trying them out. I told my dad he won't have to worry about clutch plates for his trike for awhile since I have plenty of spares laying around.
