TTS Tune
Thanks,
Took out the rinehart thundermax ecm & put back the HD ecm , loaded the Dta044-03.mt8. Have not had it on long ride yet, maybe this weekend. Tune doesn't match exactly to the rinehart true duals, will give it a try. Rinehart thundermax ecm seemed to have a good tune but was throwing codes, "time to change" - cams in the future.
Thanks,
I would guess that it is ThunderMax made by ThunderHeart and that Rinehart is a reseller just as Zippers is.
Can you comfirm this?
And what do you plan to do with the ThunderMax?
The ecm tuner is a plug & play ecm replacement "non adjustable map" for 103" with high flow A/C & rinehart full exhaust system. Rinehart performance by Thundermax. PM me for more info.
anonymous_1
09-05-2013 12:38 AM
