clutch slipping
clutch slipping
its me again . long story short .Put in new 480# clutch spring & the clutchwiz HD + oil 45oz & tighten 6 bolts to 100# got clutch cable adj. to 1/6 " went for a 46 mi ride doing 50 55 in5 gear and loveing it then want to pass a car and then the RPM when way up and the speed went 55 slipping real bad came back home running 50 55 runs good if I dont kick it . so now Im lost p.s I removed the cover & it looks find
Sounds like you too are suffering from a bad stock clutch pack. If it were good and the clutch adjusted properly there is no way it slips with the 480.
My guess is his clutch is out of adjustment per the CW website and/or his clutch pack is burnt up like other TG owners have found. Some right off the bat.
Never thought one would burn up so easily until I pulled mine with less than 5K miles. Center bands were burnt up. That's why I went with a Barnett +1 pak.
My stock clutch started slipping at the 12K mile mark. Had the heavy duty clutch kit installed at dealer. It was actually cheaper than the stock parts. Weird. I asked the service guys, and they confirmed heavy duty *is* cheaper.
The TG is a heavy beast. I was not surprised I needed it replaced. HD should have the heavy duty set up on EVERY TG right from the factory.
Listen to Wiz,
Pull your stock clutch pack and you'll probably find out it is burnt. There is a sticky from Wiz on how to do the job and install the extra plate clutch pack. Either a Barnett or the Energy One will work just fine. I'm using the E-One, also follow the recommendation about the primary fluids. The SE comp likes Formula + and the clutch likes a bit of ATF. Good luck and keep us posted.i
