Torque pervasiveness...
I was re-installing the controls on my handlebar the other day after an adjustment and, as I always do, looked up the torque setting for that screws that hold the controls to the bars. Yep, there's a specified torque. But - having watched certified Harley-Davidson mechanics install stuff I think most folks just get it "tight". When I was having my pull back bars installed I asked the mechanic what the torque setting was for the handlebar bolts. He said "tight".
So - the question is - how many people actually use the prescribed torque setting for most fasteners? I'm thinking a lot do not. What's your experience?
They sure aren't. I have 3 torque wrenches and a torque screwdriver. I do wish my light weight torque wrench was a bit smaller and lighter just for things like the handlebar control screws.
Also as Mike said he follows the manufacture's specs. Don't just tighten a bolt or nut to max specs for the fastener. The manufacture might have a different spec for a given application.
Bolt manufactures have specs for all bolts they make. But this many times is different than application.
Torque screwdriver is one thing I haven't gotten yet, may have to pick on of those up sometime. I have a couple 1/4" drive snap on torque wrenches I use for the small stuff, one is 10 - 50 in/lbs which I use on outer fairing screws.
Do you follow the torque settings for the oil fill cap?
