Have a 09 Tri, looking to replace existing slip-ons with 4'' SE w/end caps from a 08 Ultra. Any problems with clearance issues where pipes exit cut-outs? The new pipes don't seem to have as much taper as stock pipes. Thanks in advance.
I had a set of 09 CVO mufflers, not sure if they are the same size but the left one was vibrating against the differential housing so I went back to stock.
