Electric air pump for rear shocks?
Just kinda curious since I adjust my air shocks for riding 1 up or 2 up with some frequency. Does anyone make an air pump to inflate/deflate the rear air shocks that you actuate without removing the right side cover, etc.? I sometimes adjust several times a day depending on whether I'm riding alone or not. I'm not looking to replace the shocks, just a a fast and easy way to inflate/deflate.
Motortrike has a setup that works with the factory air shocks
Suspension controller >> http://www.motortrike.com/TrikeTriGlideAccessories.aspx
Just my opinion......
Ride Safe
Ride Often
I read your post with some excitement...I do get tired of removing the cover, removing the cap, pulling out the pump and buttoning it all up just to change a few pounds for different loads.
Then I saw the price (and remember looking at this a few years ago) It sure would be nice, but I just can't part with $600 for it. Guess I will keep doing it manually.
__________________
🚀 Grab a Chance at a $500 Refund! Click HERE! This DK Special ends 10/22/24 🏍️
DKCustomProducts.com
I have one on my pick-up but the control doesn't look good for handlebar mounting. I don't know if you could buy the control separately from Motortrike or not. That is a nice control. Almost has to be others around.
Their unit also goes over 100#. They warn you not to overpressure Harley's system, & tell everyone else operating the bike to do the same. Heck of a safety !!! A pressure limit switch is all it would take.
Kevin, If you come across one of the air compressors for air bags, or air shocks on cars, you can make the manifold with 2 $15 electric air valves from Ebay. Firestone puts out an air kit for the automotive end, but it has a cumbersome switch/valve w/gauge to put under the dash.
I ride with so many different loads, and on drastically different road surfaces, it would really be nice to change the PSI on the fly.
Run 22-24 lbs in the rear tires
Get a Comfort Lift Kit, not only does it level out the TG, it also helps the shocks eat up the bumps in a smoother manner
Find a road that has little traffic and is typical of what you ride. Since you're already at 15 psi on the shocks, add just 2 psi and go down that road, then add 2 more psi and go down it again. After you have gone down the road a few times, adding or subtracting 2 psi, you will discover which is smoothest for you.
For me, 1 up, 22 psi is smoothest for my typical roads. 2 up it is 28 psi.
I load up the trunk a lot of times with metal parts, and I pull a trailer a lot also, so depending on the load it is different. What I have found useful to know is that as little as 2 psi will make quite a noticeable difference in the ride quality.
Yeah, I remember back when I thought I would never use cruise control on a bike...I use it all the time now!
