Rush true duals and mufflers
I can't think of any pros because all 3 will reduce heat. The con is True dual will move the torque to a higher RPM where both the Jackpot and Xpipe will not because they are 2.1.2 head pipes like original equipment. Trikes are 1200 lbs and under powered to begin with, they need all the low end torque they can get to get that load moving.
Mike Roland did a dyno comparison of Kuryakyn true duals against the power cell ( V&H Power Dual )
Mike's qoute >> I got to do some testing again. I tested the TC-24D cams in one of our 96" FLHX bikes and the 103 I did before. The Crusher True Duals were tested against the Crusher Power Cell. It's the only difference between the runs. Conditions were near identical to last sessions tests. Correction factor was 1.00.
The Power Cell has a definite advantage above 4000 RPM. On the same bikes stock there was no advantage to the Power Cell over the True Duals. Torque curves and peak numbers were identical.Torque curves and peak numbers are close between the regular Crushers and the Mellows that there is virtually no difference besides the sound in my testing.
Mike Roland
M3 is right about the larger baffles in a muffler will move your torque to the right some
Mike Roland
