phase 7 led light with lighted halo
Just installed mine last Saturday. It will fit. Run the wires as per the instructions and remove the screw on the bottom of the halo and spread it apart with your thumbs and hook the top on. Then keep your thumbs there and pull down, apart, and push back. It will snap into place. I even called Kuryakyn and told them it wouldn't fit but I was wrong. Not the easiest install but it will go. The worst thing about it is once its on, if you break your headlight or have to take it back off for some reason, you have to pull the 3-way tape back off the ring to separate it. Not the greatest set-up but it will go on. Get your thumbs out of the way in a hurry!!
