Security System malfunction
Half way through my ride today, when I turned the ignition switch on, the security system didn't recognize the FOB and would not allow me to start the bike. I tried disarming it using the security pin number to no avail. I tried several combinations of turn signals and ignition positions the lock warning lights finally went off and I could start the trike. It's a 2009 Tri Glide by the way. Now it appears to be doing this every time I start it. I also tried the spare FOB and that didn't help either. I live in the Northwest and it is quite cold here and I have had the trike on a battery tender. The book tells me how to determine the error code but I haven't had any success with that.
Any suggestions? is this something I can fix or must I take it to the dealer and spent next month's retirement check.
Signed, Grounded!
Signed, Grounded!
Agree with Bill on battery, as far as using override its touchy sometimes.
Have to hit both blinkers right at the same time immediatly after ignition on without disturbing position of the bike.
If it doesnt like what you did you have to wait til everything settles down to try again.
Also sometimes cell phone too close to fob will make it puke.
Setting that override is very important, and remembering how to use it is as important. Friend had his keys fall out of his pocket on a long ride. Another dropped his keys in a parking lot and a car ran over his fob. Correct me if I'm wrong, I don't have my manual here, but isn't there a limited number of times you can try to unlock using the pin code before you are locked out of the system for some hours??? Pays to remember the sequence. Also, the procedure has changed on newer bikes.
Good Luck
Good Luck
Security System Malfunction
Thanks guys. I put new battery in the FOB and it is working fine now. I also replaced the battery in the spare FOB. Now if I can just get one of you guys to WASH the trike I would appreciate it.
In October I open trailered the bike to Flordia to visit a son, rode over 600 miles down there and then trailored it back to the Northwest. It is really dirty.
JC
JC
Kong
01-14-2007 08:29 AM
