Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Cigarette Lighter
Old 01-04-2013 | 10:20 PM
Harleycruiser's Avatar
Harleycruiser
Originally Posted by daurwid
Very interesting about the cables. Makes a lot of sense though. There are many different usb cables out there today. So basically do your research before buying/using one.
Well I could never find a definitive answer, there are ton of people having this same problem from HD to BMWs, and no one seems to know the solution.
I would not be surprised if the cheap cables that we get from China are defective, or burning out the wires.
I know I have had two or three that went bad charging on house current. I like the shorter ones and have been buying them online, cheap.
I have not had any problem with the original cables so guess I will just wrap the wires around the handle bars two hundred times;-)
Old 01-04-2013 | 10:26 PM
T K Glider's Avatar
T K Glider
I am still the 12 volt socket on my battery. runs my heated stuff my phone my GPS. hide the plug were the backrest goes.
Old 01-04-2013 | 10:58 PM
BinIdaho's Avatar
BinIdaho
Originally Posted by 5x40
I found that rascal. Sure enough it was there but the clutch cable had it hidden. Have no use for it, but now I know it's there. Thanks, All!
Old 08-06-2013 | 09:32 AM
JimmyT1950's Avatar
JimmyT1950
Default Cigarette Lighter
Used my cigarette lighter socket to charge my phone yesterday and it worked fine. Also, if you smoke and want to light up while riding, the cigarette lighter is kind of inconvenient to get to. I purchased a couple of flameless electric USB rechargeable lighters from http://www.extremelighter.com/ for around $10.00 each. These can be recharged using your cigarette lighter socket or and computer using the USB port. They also have an LED light built into them.
Old 08-06-2013 | 10:30 PM
dw2169's Avatar
dw2169
My GPS is plugged into mine all the time and works fine.
Old 08-07-2013 | 04:32 AM
ZBear's Avatar
ZBear
ditto on the GPS plugged in all the time, no problem
Old 08-07-2013 | 10:08 AM
acunn1's Avatar
acunn1
Originally Posted by bikerbum
Charging cable only has 2 wires connected to each connector. Data cable has all the rest connected. Never had a problem charging my Samsung phone with any charge or data cable. Samsung Tablet uses a proprietary cord. iPhone and iPad cords are different, look the same, but an iPad won't charge on an iPhone cord or charger.
Sorry but I have no problem charging the wifes iPhone or iPad using the same plug...
Old 08-07-2013 | 03:10 PM
michaelg931's Avatar
michaelg931
1st Gear
Works on my trike.
asherdav
06-17-2015 12:07 PM
Betteroff
2014-2023 Touring Models
06-09-2014 07:59 AM
discodave
03-24-2011 10:13 AM
pt4u2nv
09-08-2008 09:51 PM
capt42a
03-30-2007 07:13 AM
Quick Reply: Cigarette Lighter
