Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Cigarette Lighter
Old 01-03-2013 | 08:11 AM
Buddy WMC's Avatar
Buddy WMC
Originally Posted by BinIdaho
Left side, tucked under the facing of inside fairing to the right of your air deflectors...you will see a chrome ****...push in and wait for it to pop out and....wa-la, you have found the cigarette lighter!!
AND, what a lousy location if you want to use it for the intended use. It is not very accessible while riding JMO.
Old 01-03-2013 | 09:05 AM
BinIdaho's Avatar
BinIdaho
You are so right Buddy! Especially with bulky gloves on...if you don't hit the "hole" just right the lighter will go flying down the road (ask me how I know) lol
Old 01-03-2013 | 12:11 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I have used my cig lighter for charging phone, MP3 player, e-cig batteries, also used it to power air pumps. No problems.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Old 01-03-2013 | 12:36 PM
daurwid's Avatar
daurwid
I've used mine to charge my cellphone and GPS unit. I also use it to power my sirius satellite radio. I've had no problems doing this with mine.
Any dealer that tells you it's not for charging use is providing an excuse to not look into it. Go to another dealer or employee at that dealer and show them the problem.
Old 01-03-2013 | 03:14 PM
bikerbum's Avatar
bikerbum
Just my 2 cents worth, When your dealer tells you: cigarette lighters aren't for charging, pinging is normal, squeaking breaks are OK, etc IT IS TIME TO FIND A NEW DEALER. Would you want that person fixing your $33,000 toy???
Old 01-03-2013 | 06:36 PM
Flintshooter54's Avatar
Flintshooter54
That red hot cig lighter pulled a lot more current than any GPS or Cell phone. If it does not charge then you have a bad charger or the wire is backwards on the receptacle. If it was backwards then it might have taken out the charger as well. Won't be the first one.
Old 01-03-2013 | 08:12 PM
Harleycruiser's Avatar
Harleycruiser
Ok just found this, there is a difference between a usb charging cable and a usb data cable, I dont have time to research it more but the cable are wired differently.
that is why if you use a data cable you get the phone saying that it thinks it is hooked up to a computer but it wont charge.
http://helpblog.blackberry.com/2012/06/datasync-cable/
I remember something about the Samsung being wired backward on purpose so that you had to buy their cable.
I don't have time to find that right now, maybe later.
Old 01-03-2013 | 09:17 PM
daurwid's Avatar
daurwid
Very interesting about the cables. Makes a lot of sense though. There are many different usb cables out there today. So basically do your research before buying/using one.
Old 01-03-2013 | 10:09 PM
bikerbum's Avatar
bikerbum
Charging cable only has 2 wires connected to each connector. Data cable has all the rest connected. Never had a problem charging my Samsung phone with any charge or data cable. Samsung Tablet uses a proprietary cord. iPhone and iPad cords are different, look the same, but an iPad won't charge on an iPhone cord or charger.
Old 01-03-2013 | 10:23 PM
5x40's Avatar
5x40
I found that rascal. Sure enough it was there but the clutch cable had it hidden. Have no use for it, but now I know it's there. Thanks, All!
Quick Reply: Cigarette Lighter
