Removing Floor Boards
I have searched the threads and cant find any help,,,,I am gonna install a boot guard on the right floor board,,,can someone tell me the best way to remove the rubber part on the floor boards as it requires removing the rubber part of the flood board after removing the floor board from the trike
thanks in advance for the kelp
Spray WD40 on the rubber "bulbs" under the floorboard then just pull up; they will come right out of the mounting holes. To reinstall, I use needle nose pliers to grip the ends of the "bulbs" and pull them back through the mounting holes. Helps to lube them up again before pulling them through
RoadKingMD
General Topics/Tech Tips
09-24-2020 10:04 AM
duoglider
04-15-2010 01:05 PM
