brake pads
I used Lyndall pads with good results so far. They seem to wear well and perform better than stock imho. http://www.lyndallbrakes.com/for-har...n-motorcycles/
Received 4,251 Likes
Call Drew at Hogpro, he got me Lyndall pads for my Tri-Glide.
Lyndall Golds without a doubt. You can call Lyndall directly at 1-800-400-9490.
#7254's for the front and #7255's for the rear, double check those numbers with Paul or Jim. You also might want to think about having Paul cross drill and chamfer your rear rotors as I've done along with Icebite. Big difference, Lyndall will also be coming out shortly with composite rear rotors for our Tri's. I should be testing a set in the near future and will post the results.
Buddy....
Buddy....
Buddy....
Buddy....
