Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Color of exhaust in pipes
Old 08-24-2012 | 09:41 PM
usmc68's Avatar
usmc68
Default Color of exhaust in pipes
My 2112 tri glide exhaust is a whiteish tan color is this normal for exhaust ? I'm running Rush 1"3/4 slipons Wrapped pipes With Stage one A/C and down load. Mostly highway speed. Thanks
Old 08-25-2012 | 12:16 AM
2AMGuy's Avatar
2AMGuy
Personally, I like my exhausts to be a dark gray but I also have older bikes.
Keep an eye on other folks' bikes and see how they look.
If you're concerned about yours, ask the service manager about it the next time you go in for service.
Old 08-25-2012 | 12:24 AM
sloufoot's Avatar
sloufoot
Do you still have the cat ?
Old 08-25-2012 | 05:14 PM
usmc68's Avatar
usmc68
Yeah I still have the cat I wanted to wait till the warranty runs out to change the head pipe but,even though I have wrapped the pipes the heat may cause me to do it sooner.
Old 08-25-2012 | 05:31 PM
checkers's Avatar
checkers
On my Heritage, my pipes were black, I decatted and they turned grey, I installed XIED's and now a light gold/yellow. Runs good, cooler and good mpg.
Old 08-26-2012 | 12:04 AM
sloufoot's Avatar
sloufoot
The business of the cat is to do a re-burn on leftover hydrocarbons . That is where it gets the heat from. You should not have much of any color, other than brown or gray past the cat.
You just did a download, I guess it was a Stage 1, so you shouldn't be rich.
If you do the cat you probably will want to do a tuner, so you won't be running lean with your other mods. You could be on the lean side right now, but maybe the cat is giving enough back pressure so the flow isn't high enough.
Did they do a dyno tune when they put in the download ?
Old 08-26-2012 | 07:33 AM
Trikermutha's Avatar
Trikermutha
I think it may depend on how well the bike is tuned and how hot the pipes get..
Old 08-27-2012 | 01:58 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I am running rush slip-ons, header is de-catted, bike runs strong and cool. Inside of slip-ons are charcoal black/gray. I have the pipes & the EFI "tuned" so the AFR in the pipes is just right for lots of decel pop (which I like), otherwise the inside of the slip-ons would probably be black.
__________________
🚀 Grab a Chance at a $500 Refund! Click HERE! This DK Special ends 10/22/24 🏍️
DKCustomProducts.com
Call/Text: 662-252-8828
Old 08-27-2012 | 08:10 AM
Buddy WMC's Avatar
Buddy WMC
Kevin hit the nail on the head. Once you get the mods done like his or in my sig and your choice of tuner, when the tune is correct the mufflers will color up properly.
Old 08-27-2012 | 12:49 PM
icebite1's Avatar
icebite1
The color you described would be nice on the porcelen part of the spark plugs. Just curious but what color are your plugs?
Quick Reply: Color of exhaust in pipes
