Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
tour pak self-aligning latch
Old 04-29-2012 | 10:42 AM
grandpawmoses's Avatar
grandpawmoses
Default tour pak self-aligning latch
I've always had to kind of align my tour pak lid when I closed it. Well I bought one of those self aligning tour pak latches (part #53000195) & it works as it's supposed to. It's just two new screws and a piece of plastic that replaces the old one on the inside of the tour pak base. The new one has a tapered alignment slot for the existing tab on the tour pak lid lockset. You need a T-5 tork screwdriver & about 5 minutes of time. I ordered it on-line for $12 ($15 dealer).
David
Old 04-29-2012 | 11:02 AM
CADOO's Avatar
CADOO
David
I just put that latch on my 2012 also along with the chrome hinges. Hinges were a litle bugger to get the stock ones off,just have to be careful to not damage the paint. They say to drill out the rivets with a 3/16 drill bit but found out that a 1/8 works better,then use a 3/16 to drill out the holes bigger for the screws they put in the hinge pack. The chrome hinges look to me alot better that the stock ones if you like chrome.
Old 04-29-2012 | 04:24 PM
msocko3's Avatar
msocko3
To me both of these should be standard equipment right from the factory.
Old 04-29-2012 | 07:00 PM
tjmac49's Avatar
tjmac49
True dat!
5wheels (10-06-2019)
Old 04-29-2012 | 10:52 PM
pettifogger1's Avatar
pettifogger1
But then they wouldn't need an accessory catalog.
Old 04-30-2012 | 12:10 PM
grandpawmoses
When I replaced my hinges, I drilled out one rivet in the top & bottom of each hinge & replaced them with small machine screws. Then drilled out the rest of the rivets. After that I only needed help holding the lid for a few minutes while I swaped out the actual hinges.
Old 04-30-2012 | 05:06 PM
oldmsocko's Avatar
oldmsocko
It's not really a bad job. My bride and I changed the hinges on my TG and M3 and I changed them on his.
Old 04-30-2012 | 07:03 PM
bronxbill's Avatar
bronxbill
Veteran: Marine Corp
Being the lazy so and so that I am, I just bought the chrome peel and stick Kuryakin hinge covers. Looks fine to me, but I'm not real fussy
Old 05-01-2012 | 07:32 PM
Boom's Avatar
Boom
I also installed the retractable tourpak lid tether (54171-11) to get rid of that silly sloppy cable that would always hang out when you close the lid.
Old 05-02-2012 | 07:20 AM
CADOO's Avatar
CADOO
Did the same here.
