A Good Idea
A Good Idea
I would like to share a good idea I have done for myself. This is for all the riders that use face shields. The type that isn't fixed and is used on 3/4 helmets. I have the type that allows you to lift it and have it stay at whatever ratcheting position the helmet's design allows. Inside the shield. I used masking tape. Leaving a 2" space unmasked across the bottom. I then spray painted that black. I used flat black. The outer surface of the shield made the black have a shine to it. The reason for painting the shield is this. It will allow you to block that blinding sun, especially when your headed west at the end of the day. Just lift up your shield and use it just like a sun visor in a auto. It's so much better than riding one handed, looking like your saluting all the cages that are coming at you.
I simply used black electrical vinyl tape and taped off the top, not bottom, of my full face helmet at the top. That way I still have full vision, and not obstructed at the lower part. I don't have to raise it up either. Also, you can easily take the tape off if you want. Also, electrical tape comes in different colors, so if your helmet is red, black or whatever, match it up with the same electrical tape color. Works great for me.
If you lift your shield up on a cold day, you lose its shielding benefits from the cold. Also, I found that shield could blow off if you are trying it at freeway speeds and a gust of wind grabs you. Something to consider.
I never had that problem. The ratcheting type holds fine and the windshield on my trike keeps me from getting the full brunt of a cold air blast. The electrical tape peals after it is subjected to heat and cold. As I stated this idea is for riders that have the 3/4 helmet. Not the full face " feeling like your in sitting in a space capsule helmet" And the sun setting or rising doesnt last all that long.
The reason I chimed in on the electrical tape idea is that my modular helmet also has a flip up shield, separate from the chin bar. So your idea applies to both 3/4 and full face. However, on the modular, the paint would work also, but it would have to be at the top since you have less area for visibility on the shield surface at the bottom. Just my thoughts. I like all of the ideas.
idea. I did mine today just like you said and went for a 230 Mile ride and it was very nice being able to adjust the face shield to keep the sun out of my eyes. One of best Ideas for making riding safer . Thank you very much for sharing. Bruce
sleepyone
Gear and Other Items For Sale
11
02-27-2016 09:43 PM
sleepyone
12-11-2015 09:53 PM
condition1
02-09-2014 09:28 PM
