Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
How long without a trickle charger?
Old 10-31-2011, 09:13 PM
blade76's Avatar
blade76
blade76 is offline
Default How long without a trickle charger?
After a good long weekend trip to Asheville and the Blueridge Parkway, where it got hours of constant run and charging time, my wife's Triglide sat for exactly four weeks without a trickle charger attached (not that I hadn't thought about it!). It was dead 'er than the proverbial door nail when we tried to go for a ride this weekend with the trike (she's been riding, but on two wheels again). After a full day on the trickle charger it shows full charge again, but my question is whether it sounds normal for the battery to go so dead in four weeks. It's a 2010 with just under 19K miles, security system and a remote control led light system (trying to think of all the things that might affect drain). Does that sound normal, or could we have an undetected drain - or just a bad battery (seemed to take a charge just fine from the charger). This is the second time this has happened, although the first time I think was more like three weeks. I have nothing against using a trickle/maintenance charger, it just seems odd. I have a car that sits for weeks at a time and it never seems to have a problem!
Old 10-31-2011, 10:08 PM
BLKBAGGER's Avatar
BLKBAGGER
BLKBAGGER is offline
I have never used a trickle charger in my 35 years of riding. I have let bikes sit for weeks at a time with zero issues. You have got something draining your battery.
Old 10-31-2011, 10:27 PM
wiltat2's Avatar
wiltat2
wiltat2 is offline
I never had a problem with any of my bikes needing a trickle charger until we got our 09 TriGlide and 10 EGUC. They both have the security system in them and it does drain the charge on the battery. If I think one is going to sit for more than 3 days I put the charger on it and don't worry about it.
Fortunately living in Yuma, Az. it is not to often one sits for more than 3 days, unless we go on a trip on one of them.
Old 11-01-2011, 12:02 AM
screwball's Avatar
screwball
screwball is offline
Wife's '11 has gone 3 weeks without a ride, and it started right up. My '09 rarely goes a day or two without being ridden. Both have the security system.
Good Luck!
Old 11-01-2011, 04:34 AM
oldmsocko's Avatar
oldmsocko
oldmsocko is offline
Not all batteries are created equal. There is a drain on the battery when not running because of the security system and you have a clock that is keeping time. I believe it is a good practice to put the bike on the tender if it is going to sit idle for more than 2 or 3 days.
Old 11-01-2011, 05:47 AM
Bubba49's Avatar
Bubba49
Bubba49 is offline
I put a tender on mine when it gets below 40 degrees. I also try to start the trike and warm it up every few days just to make sure everything is okay (That also satisfies my need to hear the thunder). My Deluxe went dead on me last year in the dead of winter because I didn't put it on a tender.
Bubba
Old 11-01-2011, 11:46 AM
bronxbill's Avatar
bronxbill
bronxbill is offline
Veteran: Marine Corp
My indy says that 3 to 4 idle weeks on a bike with a security system will probably discharge the battery
Old 11-01-2011, 12:02 PM
BQ2's Avatar
BQ2
BQ2 is offline
Have the same problem with my Softail Custom. Dealer & the Forum confirmed what you found out the hard way. Everyone says it's the security system.
Old 11-01-2011, 12:15 PM
FUBAR55's Avatar
FUBAR55
FUBAR55 is offline
Bought 2 Battery Tender Juniors. Takes 30 seconds to hook em up to both bikes.
Why wouldn't I?
Old 11-01-2011, 12:34 PM
Boom's Avatar
Boom
Boom is offline
I have a LoJack on my TG and I've been told that if the trike's battery goes dead, the LoJack has a backup battery that won't last long without the trike's battery. Then, of course, the Lojack is useless.
Quick Reply: How long without a trickle charger?
