Cat removal -- phooey
Mr. Wizard's post showing before and after engine temps was really good. I don't like and don't want anything that requires a Windows based laptop to install or tune a device or that requires a dyno to get the thing to work. All I read about and hear from friends with these devices (and from my limited experience) is constant complaints about needing a new map, needs adjustments for running above sea level, etc., etc., and constant problems with the PCV and even the Thundermax, which is advertised as plug and play but apparently still needs map downloads and tweaking. Is there a device/tuner that is truly plug and play? I don't want to buy and become proficient with a Windows based laptop to get a tuner to work and don't want to try and find a local dealer with a dyno.
I haven't expended any energy on it but I think I might even be able to get the TTS software to run under Ubuntu which is a Linux based operating system by using WINE.
i think alot has to do with were you live and what you expect. i live in kittery,me. on the coast and drive to western me, the mountains and have plenty of power. the trike does get hot on the right side but not anyhotter than my 2004 soaftail did. i'll leave mine stock for the first year and maybe next year get a rear bumper. my 2011 has no problem running 2 up in 6th over 55 mph. and has plenty of power for me.
"I haven't expended any energy on it but I think I might even be able to get the TTS software to run under Ubuntu which is a Linux based operating system by using WINE."
This would be part of the problem. I don't have a Windows based laptop and I have no idea what you said. Isn't Ubuntu what Obama speaks?
Bike runs fine. Just went to beach on east coast from Indiana, road thru mountains on way back. No laptop needed. I know I could use the furnished stuff and a laptop to put a fine tune on it but I bought it to ride and that is what I do.
Plugs read fine, riding two up get 35 MPG. This trip, yea we were hot, not because of bike, it was just very hot unless you were in your AC at motel.
I ride in what I call a flower sniffing mode. Just run the posted speed limit, run two lane and interstate. It is all good and that is why I have the TG, to tour on it, does what it was built for IMHO.
Dennis
What M3 is talking about is simply the fudge factor between bikes. Not all bikes, even with the same equipment, will breath the same. Thus, a canned calibration from a vendor will not be as close as you could get by doing the tune yourself or by a diagnostician. You are leaving a lot of tuning possibles on the floor. Even the Vision Pro can be incorporated via an auto tune function to calibrate your motor VE tables but that is even more money that is added to the product cost.
The VE Tables (Volumetric Efficiencies) are what tells the ECM how your motor breaths so the proper amount of fuel can be added. No two motors breath alike. Canned maps (calibrations) are like throwing darts, sometimes you hit the bulls eye and other times you can't even hit the wall.
What ever tuning aid you use... if it makes you happy then that's the bottom line.
Cheers... wiz out
Cheers... wiz out
I have a question for Mr. Wizard, especially after your insights on motor breathing. I sent an email to Jaime at Fuel Moto and he said they could program a PC-V for my setup. (I.e., cat begone, Fatshotzs and AC. That is all I ever intend to put on as far as engine mods are concerned so this will be a one time affair.) Or I could get the Power Vision and that rather than being an add-on like the PC-V it "flashes the ECM directly and uses the factory O2 sensors." Since all of the experts have said the stock 02 sensors are narrow band and, therefore, junk, would spending the fairly significant amount of extra cash on the Power Vision do any good? If the stock 02 sensors are so bad, how does the Power Vision use them? Sounds like the only practical difference between the PC-V and the Power Vision is that the Power Vision comes with a device to download a map, but once downloaded it really doesn't perform any function. For my setup, what would be a good solid, easy to use, device? Or is there a better choice? My big fear is getting stuck on the side of the road 50 miles outside of East Jesus, Nevada, and having no one with a computer that speaks Ubuntu so I'm stuck. At least with the PC-V and similar devices I can unplug it and throw it in a ditch like I did with the last one.
I'll send you some information via PM.
