At Last An Oil Cooler That Actually Lowers The Temp of The Oil
Thanks for all the replies. I "assumed" that the air temp gauge (useless) was changed to an oil temp gauge. I have HD do all work on my TG. Could you give me a cost estimate to change out air to oil gauge?
(Didn't we have an oil temp discussion when the TG's first came out...mine was running 280* with the non-TG led dip stick. Of course the HD service said that was "normal"...I'm beginning to hate that word!)
Some frugal people slap a temp gauge on the crash bar, you don't have to crack the case on the fairing and leave your worthless air temp gauge in. Plumbed into the oil pan for real heat indication, hard to see but who stares at the temp gauge all the time. I can lean forward at lights and take a peek at it from time to time...
I guess it's possible that Jagg come up with the fan on the 10 row idea on their own but it does seem odd that after a couple years of the forum people posting their add on fans that Jagg jumps on the fan wagon.
I just plumbed the old Jag in straight, oil pressure is a solid 32 lbs. when warm so that tells me the oil is staying in the cooler about as long as the other plumbing route. I can see going through the filter if you had an aluminum finned filter cover or a finned filter for extra cooling. I don't think you are going to pick up a a significant amount of extra cooling by just routing through the oil filter..
I think people would be very surprised as to what their oil temp really is. In a perfect world you would like it to be around 200 degrees, that is not going to happen in a air cooled engine. Getting it too 230 has been expensive but will add greatly to the longevity of the engine and rider comfort. A digital temp gauge is an eye opener and a great add on to your scooter. Harvey Dawson don't want you to know how hot your engine is running because they don't want to address the problem as it would cost them a bunch. They also like things wearing out to keep the revenues coming in. Use a good fully synthetic oil, I know there are the nay sayers out there claiming dino stops corrosion but if its worn out from heat and wear less corrosion want help. Heat kills oil plain and simple. Fully synthetic oil maintains its lubricating properties THREE (3) times the temperature, nuff said. Knowing what is happening in your engine is the only way to combat the problems or listening to some other fool that has already been there. I'm raising my hand here. Thanks, Jerry
