why would you need to replace the HD oil adapter with a Jagg adapter?
wouldn't the HD adapter work with the jagg 10 row cooler?
thanks
dan
Yes it will with the old style oil cooler. M3 and I put on the 10 row Jagg and used the HD adapter. Possibly the newer style will require a different adapter. Your best bet would be to contact Jagg and inquire if the HD adapter will work.
It looks like Jagg is mounting the thermostat for the fan in a fitting on their adaptor. I would guess a person could direct wire the fan to a switch and skip the thermostat.
Wow, is it $500.00 better than the oil cooler that comes with the trike? By the time you buy the cooler, the adapter and the nipple it's a little pricey considering the Harley cooler is a pretty decent cooler.
yea I read a lot of post on the thermostat when we switched ours, I wired straight to the ACC Switch and just used my original plumbing. I don't want it running until I hit traffic...
