Wow, is it $500.00 better than the oil cooler that comes with the trike? By the time you buy the cooler, the adapter and the nipple it's a little pricey considering the Harley cooler is a pretty decent cooler.
I put the jagg 10 on with the arizona fan kit, wired to the acc switch! I think it was $159 for the new cooler and $69 for the Fan Kit. We had no other options at the time..
It does a good job, the advertised 800 cfm may or may not be there and the new fan on the new Jagg 10 looks beefier but the ol twin muffins on the 10 row seem to do the job...Of course I am a little frugal!
What's the differnce between the standard H-D oil cooler and the H-D premium cooler other than price?Would the premium be comparable to a jagg ?
the standard is a 5 row and the HD premium is an 8 row with what they claim is a better design...The Premium should have been on all the Trikes minimum OEM equipment with a Fan.
Of course then the dealers couldn't sell you and 8 row HD! I would rather have the Jag 10 for the price and got a couple extra rows!
Guys I don't have a trike but ride a Road Glide Custom , I installed the 1st Jagg 10 row low mount Fan assisted unit Marv at Jagg released , I did a write up in the Touring Section , my bike with a 103 power pak motor came with the HD oil cooler , first the Jagg 10 row by it's self cooled way better than the HD unit and the fan worked as it was intended , I changed to the Jagg oil filter adapter as well but the HD adapter will work , the reason I changed is the Jagg adapter has a higher flow rate and less pressure drop on start up than the HD adapter , do a search on my results , ride safe TJ
Originally Posted by oldmsocko
Mine runs considerably cooler with the 10 row Jagg vs the HD cooler.
