Jagg 10 Row vs Ultra Cool
#33
Well then I'll give it a try with the Ultra Cool install. Dealer found a defect in the front fender while doing the detail, so we are working on a solution for that now. Otherwise, the detail work was outstanding. Still waiting for the Ultra Cool parts, rear trunk seal and oil temp guage. My dealer is giving me a break on the install as they have to remove the outer fairing under warranty to replace the guage. Yup, I have a great dealer, anyone have any options for the rear mud flaps other than the HD's?
#34
Buddy, I also was concerned about air flow to the cooler, especially after all the mods i did to cool the beast down.
I did get the timberwolf flap just recently. Befor installing it i took a old cassett tape and made some streamers that i attached to the bottem of the fender with tape and rode the TG, The streamers did fllow but were a little squirrely, i then installed the flap leaving the streamers on and rode again. They were still flowing but a little worse than befor.My conclusion was that it was better than pluged with debris or damaged to use the mud flap verses the minor apparent flow increase without it.
Not too scientific but it helped me make a decision.
Any of you that didnt see the post on the drilled rotors from Lyndall i finally got to try them and they do help with rear braking.
#35
Air Flow
The only advantage of an Ultra Cooler or the Jag 10 with the fan is sitting or idling in traffic. The fans moving air over the extra coils is where those cooler shine, idling in traffic on a hot day!
It makes no difference about the front fender flaps when you are at speed/in the wind! There is enough air movement through the coolers either with flaps or flapless. At idle/stopped there is no air movement, thus the need for the fans!
#36
#37
#38
Black Widow HD in Port Charlotte, Florida. They have a website up if you want to Google it up. I'm on a first name basis with everyone in the service dept. They are closed on Mondays, so next week the service manager and his assistant are riding down to see our little operation. Really good guys to work with. They found a couple of issues during the first service that I was not aware of. Parts are on order and they'll take care of the replacements under warranty when they come in.
#39
Boom,
#40
The dealer I've been going to for years begs me to give them all "10s" whenever I get a survey on them from the Moco. If I do, I get 10 rider points which is worth 10 bucks towards a purchase in their shop. This is how they get those gold awards. Finally after 10 years they know me on a first-name basis! Time to move on---in 18 months!
