Noisy lifter........
noisy lifter
I just turned the stereo back on, I think they are all a little noisy except for the people that change CAMS and go with aftermarket lifters. If it is not excessive I would not be concerned!
Mine seem to be a little ticky when I am in 6th gear...sometimes I feel like the ticks are the engine coming apart. I am more use to the goldwing sound, so never had a V-twin before. I just had a my 1000 mile service. Maybe I should take it back and ask them to test drive it in 6th gear. I am getting my rear wheels upgraded to the chrome ones next week. Am going to ask them to check it out when the trike is in then.
I wouldn't worry about it unless it seems to be getting worse. One of the reasons I've gone away from using HD lifters in my engines is the crappy quality. When I did the 95" build on my 06 I installed a new set of HD lifters and after about 20,000 miles one started to bleed down after it sat for a day. I installed Head Quarters black op lifters in both mine and my dads Triglides this winter when we did the cams and I just replaced the lifters in my 06.
At about 10K mine started to get real noisy when starting cold and also a few times when stopped after a 100 miles or so and then restarted. Lifters were definitely leaking down and the dealer replaced all the lifters under warranty without a question. Of course they were replaced with stock lifters so who knows how long they will last. Hopefully, as long as I own it. At 67 years old I don't know how many more new bikes I will buy but if there is another new one I'm not sure what it will be.
at about 55 or so. I have heard others say not to go to 6th unless you are at 65 or higher. But since my TG is 2011 and has the 30 tooth, I felt it would work at 55 or so....am I wrong? I think the RPM is near 2200, if I remember correctly.
I'd try not to go any lower than 2,500 unless your on a dead flat road and not going to accelerate. Its hard on the bottom end and could shift the crank.
