Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Noisy lifter........
Old 03-20-2011, 07:07 AM
Boom's Avatar
Boom
Boom is offline
Originally Posted by msocko3
I'd try not to go any lower than 2,500 unless your on a dead flat road and not going to accelerate. Its hard on the bottom end and could shift the crank.
+1 on that! I have the 30 tooth pulley on my '10 and feel that's about the right RPM to prevent lugging.
Old 03-20-2011, 07:12 AM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,684 Likes on 3,119 Posts
Lifters often tick for the first 20 seconds after start up, and tick at idle when the oil thins out...No worries.
Old 03-20-2011, 10:02 AM
icebite1's Avatar
icebite1
icebite1 is offline
IMO, Yes lifters do often tic. But think about it, hdy lifters are not supposed to tic, if they tic they are bleading down too much and your valves are not opening all the way which on the '07 up with epa cams means the exhaust is held closed even longer causing more heat especially at idle. Im not saying the bike wont run that way and probably most never see a problem.
Me I change them out.
JONNIEROCK
09-16-2013 07:12 PM
Mo.Rob
08-13-2013 06:15 AM
mikebehr00
Exhaust System Topics
08-10-2012 01:35 PM
jmcd
05-03-2011 04:18 PM
rlyons
EVO
04-15-2009 12:33 PM
Quick Reply: Noisy lifter........
