OK, I know we've gone over this before.........I have eye bolts in the floor to strap down the front wheel, a 1700 lb auto hydraulic jack for under the metal plate behind the engine, and even a 1500 lb. Craftsman jack for backup. But I'm not comfortable about relying only on that jack when this 1200 lbs. beast is back-ended off the ground. Is it safe to put jack stands under the shock supports or what is the alternative?
I use a two ton floor jack with two 2x6 that reach the two struts the trunk sits on. It makes it easy to jack up while I push my car ramps under the ck up the front wheels and then jack up the front wheel where I place a 8x8 cut the same height as the jack stands. This allows me to work under the trike as well as the engine. It is a pour mans work around.
