Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
It's dead.
Old 02-06-2011, 09:39 PM
peddler's Avatar
peddler
peddler is offline
I normally pull the battery out of my Ultra for the winter. The bike had been sitting for several weeks when I finally removed the battery and put it on a battery tender. What voltage should I look for that would indicate the battery is fully charged? There is a piece of masking tape on the battery that indicates the measured voltage fully charged was 14.1 volts in 2009. Is there a mnimum voltage I should look for to determine if a new battery is or isn't required?
Old 02-07-2011, 03:19 AM
msocko3's Avatar
msocko3
msocko3 is offline
If you have been having no starting issues I wouldn't sweat it, the battery is still pretty new. I normally replace the battery every 4 years, but then I'm kind of **** about certain things. If your concerned you can have dealer test it, they can put a load on it and tell if there is a bad cell.
stovebolt_six
09-04-2015 09:30 PM
Vilrandir
Electrical/Lighting/Alarm
08-13-2015 04:32 PM
PHA-Q
10-18-2011 07:53 AM
st john
01-14-2011 10:14 PM
Rynb15
15
08-16-2008 06:18 AM
Quick Reply: It's dead.
