Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Parking brake adjustment
Old 02-02-2011, 05:45 PM
dw2169's Avatar
dw2169
dw2169 is offline
Minor adjustments are done at the handle by rotating the **** otherwise it is back at the wheels.
Old 02-02-2011, 06:23 PM
wiltat2's Avatar
wiltat2
wiltat2 is offline
The annoying thing to me about the parking break is, it was a problem on the old 72 Servi-car I had and then it is a problem on the new 09 TG I bought. I sure would have thought they might have figured out how to do it right after having it wrong before.
I always parked the Servi-car in gear and just do the same now with the TG.
Old 02-02-2011, 06:52 PM
krw's Avatar
krw
krw is offline
I also leave the bike in gear when it is parked.
Old 02-03-2011, 06:19 AM
Boom's Avatar
Boom
Boom is offline
Originally Posted by oldmsocko
I didn't think it got cold in Virginia. Heck Boom, bring it on over, you can use my garage.
Mike, thanks, but I don't think I could plow through all that snow you got up there!
Old 02-04-2011, 10:59 PM
Vernl's Avatar
Vernl
Vernl is offline
Originally Posted by Rob C
Can anone tell me how to adjust the parking brake on a 2010 Triglide. Searched for old threads and found none! Do not have a service manual yet. It looks like it should be easy, but I can't figure it out and I don't want to break anything since it is the wifes trike!
Thanks,
Rob
Good instructions in the owners manual, no need to pop for the service manual
Old 02-05-2011, 06:11 AM
oldmsocko's Avatar
oldmsocko
oldmsocko is offline
It is always a good investment to purchasing the service manual if you plan on doing any work yourself.
Old 06-17-2011, 05:30 PM
SpringerRick's Avatar
SpringerRick
SpringerRick is offline
Stage I
Owners manual has minor adjustment for parking brake. But if the brake no longer holds, you will have to do the Park Brake Adjustment (Section 1.12) from the Service Manual. After putting new brake pads on the trike I adjusted the parking brake. On page 1-19 in the FLHTCUTG Service Manual under Park Brake, make sure that you pay special attention to #2 (the set screw is inside the brake handle, this loosens cable) and #5 when doing the procedure. Worked like a charm. The parking brake holds again!
wengerda
08-02-2018 10:27 AM
johnd5412
06-30-2014 10:52 PM
skim1420
07-06-2009 06:20 PM
thumperhumper
Wheels/Tires
04-19-2009 05:32 AM
harleybob98
06-21-2006 01:58 AM
Quick Reply: Parking brake adjustment
