Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Want To See A Triglide Piston
Old 01-19-2011, 09:57 AM
msocko3's Avatar
msocko3
msocko3 is offline
Originally Posted by coupe55
How are the cylinder walls holding up did you pull it down off TDC and check the walls?
Yes I did and they looked pretty good, I'll have to see if I can remember to take a picture.
Old 01-19-2011, 03:22 PM
coupe55's Avatar
coupe55
coupe55 is offline
Default Cyl. Walls
Mine look good through a bore scope, the oil analysis was clean but was concerned about the suck back off the drilled Cat. I don't believe with the lift and duration of that stock EPA cam it is going to be a problem.
I just hate to throw something out on a foum that would cause someone to mess up their engine. From all indications the drilled cat is causing no problems, Trike also runs good and cool so not sure if I am going to go with the catless headpipes. Maybe next winters project!
The drilled cat, XIED's and 11 gear seem to be a good poor mans tune!
Cuts way back on the Harley Tax and leaves you near stock if you want to go back!
Old 01-19-2011, 04:02 PM
msocko3's Avatar
msocko3
msocko3 is offline
I believe the folks with the 11's are onto a pretty good thing, just a little heat management and their styling. Here is a quick picture of the cyl.
Old 01-19-2011, 06:13 PM
coupe55's Avatar
coupe55
coupe55 is offline
Default Cyl Walls
Nice! The walls look good! I always thought we got a lot of oil splash on the pistons once we got em cooled off a little. It's the heads that take the beating!
good luck with the build!
Old 01-20-2011, 04:22 AM
oldmsocko's Avatar
oldmsocko
oldmsocko is offline
Since its a build on my TG, I wish him all the luck in the world.
Old 01-20-2011, 08:42 AM
coupe55's Avatar
coupe55
coupe55 is offline
Default Home Cookin
Rubbing it in again, you know we smoother over your home grown mechanic.
Good thing he caught that bone head fix the dealer put on that compression release. Imagine if you guys had been on the road and that thing gave out. Hang in there, spring is just around the corner!
Old 01-20-2011, 03:33 PM
oldmsocko's Avatar
oldmsocko
What you really don't understand he is just a chip off the old block.
springer_
Exhaust System Topics
07-25-2023 02:56 AM
gartec81
04-02-2016 12:01 AM
Lockeshill
Engine Mechanical Topics
19
08-17-2015 11:44 AM
RRTX_FSTLN
Shovelhead
10-11-2014 02:47 PM
hollywoodultra
03-01-2009 10:47 AM
Quick Reply: Want To See A Triglide Piston
